I had problem in Civil 3D functionality so i reinstall but forget to move pipe catelog file so while i am going to add or edit parts its shows set pipe catelog and part is not found. i made custom parts and saved it on default path. but after reinstallation i m not able to edit parts. so please help me what to do? and ya make new parts with same name but its not taking replacement.
You will probably get a better forum for your answer in the Civil 3D forum found here.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/bd-p/66
This stormwater forum is basically for using the two software products "SSA", Autodesk Storm and Sanitary Analysis and the Hydroflow programs.
It would be a good idea to give your system specs as well as the version of the C3D you are working with.
Bill
