Hi all,
I do appreciate in advance for your help and time.
I am modelling a sewer pipe network in SSA. At some stages we use varies pipe materials with different wall thicknesses. So I want to know how can I assign inner diameter of pipes in SSA so I just deduct wall thickness from pipe diameter and then assign it to the pipe. Or is there any possibility to make a pipe list whith specific properties like part builder in civil3d?
Regards.
This may not be the best Forum for your answer. This Newsgroup is more related to the software functions of the program. http://forums.autodesk.com/t5/AutoCAD-Civil-3D/bd-p/66
However, you can pick from several types of pipes (Concrete, HDPE, PVC, Corrugated Metal, Ductile Iron & Corrugated HDPE). Surely one of the these will be close enough for your applications, then just select the INSIDE diameter you want. Wall thickness is already calculated.
Bill
