AutoCAD Civil 3D General
Distinguished Contributor
Message 1 of 19 (4,835 Views)
insert georeferenced images
4835 Views, 18 Replies
08-08-2011 08:43 AM
I need to insert a georeferenced TIF file into 3d.
I tried MAPIIMAGE and the image came in the middle of no where.  It does have a tfw file.
The settings of the drawing are set at US feet NAD 29 PA N
I can't get the map workspace to come up.
The help function was not help ful per usual.
Can anyone help?
Message 2 of 19 (4,819 Views)
Re: insert georeferenced images
08-08-2011 10:34 AM in reply to: annw2
Try MAPIINSERT.
Message 3 of 19 (4,814 Views)
08-08-2011 10:46 AM in reply to: jones14
Sorry:
I did use MAPIINSERT.  Brain freeze.  The image still winds up in the middle of nowhere both in 2011 & 2004.
I looked at the data file that came with the TIF.  I didn't see units in it anywhere.
*Expert Elite*
AllenJessup
Message 4 of 19 (4,796 Views)
08-08-2011 12:38 PM in reply to: annw2
Did the coordinates in the TFW file look line they would fit the coordinate system you're working in?
Allen
*Expert Elite*
Joe-Bouza
Message 5 of 19 (4,781 Views)
08-08-2011 02:35 PM in reply to: annw2
I don't think it can tell where to go without a world file? Did you try raster insert>> world file?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
*Expert Elite*
Murph
Message 6 of 19 (4,774 Views)
08-08-2011 05:04 PM in reply to: annw2
Using MAP image Insert does NOT transform the image if it is NOT in the same coordinate system as your dwg. Using Data Connect does.
MAPWSPACE should open up the map task pane.
Murph
Supportting the troops daily.
Message 7 of 19 (4,675 Views)
09-29-2011 02:38 PM in reply to: Murph
OK. I managed to insert other images correctly with MAPWSPACE with the drawing settings to the same coordinate system as the image.
I now need to bring in NAD 83 m quad maps and transform to NAD 27 feet.
the data connect gives me unknown on the left.  when I set the over ride to NAD 27, it doesn't line up with the 3d data.
I am not seeing instructions under Map help.
2012.
*Expert Elite*
antoniovinci
Message 8 of 19 (4,663 Views)
09-30-2011 03:13 AM in reply to: annw2
1] open the Nad83 drawing
2] _ADESETCRDSYS and set the right reference system on Nad83 datum
3] save and close
4] open a new empty drawing
5] _ADESETCRDSYS and set the right reference system on Nad27 datum
6] _ADEDRAWINGS and attach the Nad83 drawing
7] _ADEQUERY => Location => ALL => OK => Query mode DRAW => Execute query => OK
Message 9 of 19 (4,630 Views)
10-05-2011 02:21 PM in reply to: antoniovinci
I get to the _ADEDRAWINGS command and get a pick box that will only look for files on my local drive and won't look on the network where I saved the file.
I will try doing a SAVEAS to the local drive, but I will need to be able to reference the server for future projects.
I tried hitting the help key when the pick box came up and it said the web site was unavailable (Again)
Message 10 of 19 (4,629 Views)
10-05-2011 02:36 PM in reply to: antoniovinci
I did the _ADEDRAWINGS and it seemed to do something.
I did the _adequery and the execute query gave me messages about some objects can't be queried.
I got messages about parcel and alignment handles.
I didn't see the TIF anywhere on a zoom extent.
I last used MAP in a class 10 years ago.  The on line user manual does not seem too helpful.
I tried a search for tutorials and came up empty.
This can not be that unusual a function that it is so complicated.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
