contour lables have a line or tic mark in the middle of the text. Is there a way to turn the lines off globally?
Not sure if this is what you are after - Toolspace > Settiings > Right Click Surface > Edit Feature Settings
neilyj (No connection with Autodesk other than using the products in the real world)
And to turn them off for labels already added to the drawing:
Select one, right-click, select similar. This should select all of them in the drawing (as long as the layer they are on is thawed). Go to the properties palette and turn off the display of the contour label lines.
