Depends on the format of those sections. If they are or can be exported as
polylines with elevation, then yes, we can import them into a Civil 3D
drawing and then build surfaces from them. Same idea if you can get points
exported from those sections. You can import the points, and build a
surface from them. If its a proprietary format, then probably not though.
Anthony Governanti
Autodesk, Inc.
Visit my blog: www.autodesk.com/wickedcoolstuff
I dig it! Do you? Join the Civil 3D Community Now!
http://civilcommunity.autodesk.com/
wrote in message news:5319522@discussion.autodesk.com...
Is there a way to import original ground cross sections into Civil 3D? For
example, in EMXS you can survey on station and then the design and earthwork
volumes are taken right off the cross section without creating a DTM. I'm
pretty sure the answer is no, but just need confirmation.
