PLS ANYONE TO HELP ON HOW TO GET DATA FOR SITE, E.G CENTRELINE COORDINATES AND ELEVATIONS
You'll have to expound on this request a little.
Centerline coordinates can be obtained by doing a Station&Curve report. There are various reports that will provide coordinates/elevations of points in relation to an alignment.
What i need is how to get coordinates & elevations of chainages of a designed road
You have a corridor, correct?
If you have set your Point Codes correclty (see Code Set Style,) you can select the Corridor on the screen, and then on the Ribbon, expand Launch Pad and select Points from Corridor.
Once you have created the points for the feature you want reported, go to the Toolbox tab of the Toolspace, expand Reports Manager, expand Points, right click Station Offset to Points. This will chainage, offset and elevations.
Best regards,
Tim
