AutoCAD Civil 3D General
Active Contributor
Message 1 of 6 (661 Views)
Saving new .lin file
661 Views, 5 Replies
02-25-2013 09:13 AM
I want to create a new custom linetype and edit the acad.lin in Notepad. Instead of saving over the original file, I did a save as, but Notepad can only save it as .txt file, not .lin. Whenever I go to load the new linetype file (which is in .txt), it doesn't recognize it, and only shows the .lin files. How do I save .lin file in Notepad?
Valued Mentor
IanMcClain
Message 2 of 6 (654 Views)
Re: Saving new .lin file
02-25-2013 09:48 AM in reply to: dorkyfreak
I'm using windows 7 and notepad can save as .lin if you type it in before saving. Maybe that is not true of older versions, but in that case I would just rename the file in the windows explorer folder.
-Ian McClain
(running C3D 2012 sp4, Win7 64bit, 8GB)
Active Contributor
Message 3 of 6 (636 Views)
02-25-2013 10:18 AM in reply to: IanMcClain
I'm using Window XP. How do you modify the extension of the file? I tried adding ".lin" at the end of the name of the file, hoping it'll change to LIN type file, but it remained as a txt file as <filename.lin>.txt.
Valued Mentor
IanMcClain
Message 4 of 6 (631 Views)
02-25-2013 10:26 AM in reply to: dorkyfreak
Right click the file in windows explorer, delete the txt and replace with lin. You will probably get a message/warning pop-up asking you if are sure you want to change the file type, click yes/ok.
-Ian McClain
Active Contributor
Message 5 of 6 (627 Views)
02-25-2013 10:37 AM in reply to: IanMcClain
Thanks! I also figured out that my problem is more of a window question on how to show the extension file in the filename. Once i figured out how do that, it was easy breezy. Thanks for responding to my issue!!!
Valued Mentor
Message 6 of 6 (593 Views)
02-25-2013 05:07 PM in reply to: dorkyfreak
when saving the file from notepad, you can also save the file with the ".lin" extension by selecting to save it as "ALL FILES" as the save type, instead of the default ".txt" type (see attachment)
Civil 3D 2013 SP1, Win 7-64 bit
12GB RAM
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
