Unless someone comes up with a way to not do it programmatically, I would copy the rule you want and add a line in the code to change the flow direction when the rule is applied or modify the existing rules if you always want the slope change to happen. Check out my AU class for more information on how to create pipe rules in 2008. I haven't looked in help to see if it was added for 2009.
Christopher
http://civil-3d.blogspot.com/
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
