TGKDG wrote:
> I have pipes in profile. They sumps are supposed to be equal with
> the lowest invert in the manhole. I've installed SP2 for 2007 and I
> am no longer able to move the sumps either by moving the arrow in the
> profile, or by changing the sump depth in structure propeties or
> changing the rim to sump depth in the same properties.
This seems to be an issue with your install. I'm able to not only
graphically edit my sump elevations with the grips, but change the value
in the structure properties as well. You've either got a corrupt
drawing (run an audit?) or a corrupt install.
Also, this from the readme:
There is a known issue with the Part Lists in Autodesk Civil 3D drawing
templates. Drawings created from Autodesk Civil 3D drawing templates may
contain corrupt Part Lists. Creating Network References using these
templates may cause Network Reference parts to be drawn with incorrect
dimensions as compared to the shared Project Network. It is recommended
that all Part Lists be deleted from the Autodesk Civil 3D drawing
templates, and recreated with the New Parts List command. Dragging and
dropping Part Lists between drawings is not recommended.
Jason Hickey
Civil 3D 2007, SP2
Dell Precision M70
2 GIG RAM, 256 MB nVidia Quadro FX Go1400
Intel Centrino 2 gHz Processor
www.civil3d.com
