AutoCAD Civil 3D General
Active Member
jmellett
Message 1 of 6 (1,212 Views)
Accepted Solution
Object Properties Window Hidden
1212 Views, 5 Replies
03-27-2012 02:32 PM
We run 2012 Civil 3D.  We recently loaded an application which provides tabs of mutiple open drawings at the top of the page so you can easily switch between drawings.
I typically dock my Object Properties Window on the left side of my window.  Once we added the application, I can no longer access my Object Properties window.  It is slightly visible within the window where the drawing tabs are.  However, it is only 2 -3 lines of the window.
I cannot drag the properties window to another location.
I tried removing the application for the drawing tabs.  However, then I cannot access the properties window at all.  It says it opens and closes but it is hidden.
Any ideas??
It is a hard thing to expain.  I hope I did it justice.  I attached a screen shot to try to show the problem.  The properties window can be seen in the top left corner.
Valued Mentor
gjrcmb
Message 2 of 6 (1,189 Views)
Re: Object Properties Window Hidden
03-27-2012 06:14 PM in reply to: jmellett
Just guessing at possible solutions!!
It does not appear that the Properties palette is locked in position, because in your screen shot I see the Toolbars/Window Positions is Unlocked (Lock Symbol icon or LOCKUI system variable) on the lower right side on your Status Bar.
Are you able to right click on Properties palette and select Close, and then reopen the Properties window?  Does hitting Ctrl+Shift+H twice to HidePalettes and then ShowPalettes do anything?
Active Member
jmellett
Message 3 of 6 (1,175 Views)
03-28-2012 06:23 AM in reply to: gjrcmb
Correct...it is not locked.
I can right click and close it.  However, when I reopen it..I have the same problem.  I cannot drag it to move it.
Ctrl+Shift+H cleans the screen..for lack of a better explanation.   Same problem when I hit it again.
corcad
Message 4 of 6 (1,165 Views)
03-28-2012 08:26 AM in reply to: jmellett
When you right click on the palette are you able to use the move command. If you can, then use your arrow keys to move it back into view.
Matthew Corbin
Valued Mentor
gjrcmb
Message 5 of 6 (1,156 Views)
03-28-2012 10:21 AM in reply to: jmellett
Try opening up the Customize User Interface (CUI command), select your Workspace on the upper left, expand the Palettes node under Workspace Contents on the upper right, then select the Properties palette.  Still in the CUI with the Properties palette selected, under Properties on the lower right change the Allow Docking to "No", or change other settings to see if that corrects the situation (see attached image).
This is based on another posting I found:
Missing Properties Palatte
http://forums.augi.com/showthread.php?t=94121
If still no resolution, you may want to consider running a repair on AutoCAD or reinstalling if the problem still is not resolved, unless someone else has an idea.
Active Member
jmellett
Message 6 of 6 (1,153 Views)
03-28-2012 10:24 AM in reply to: gjrcmb
Thank you for your input.  I did not try the last post.
We decided to run a repair on AutoCAD.  Wasting too much time!!!
The repair fixed the problem.
Thanks again.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
