Civil 3D Forum
Lane Transition
9 REPLIES 9
Message 1 of 10
evanhughes
754 Views, 9 Replies
Lane Transition
Hi All
I need a transitional subassembly right and left sides with 5 layers each able to be set at different depths.
I need the edge of carriage way point to be as the std UK transitional lane. Change offset and grade, hold grade change offset, etc.
The layers and there default depths are as follows
Surface 40mm
Binder 60mm
Base 125mm
Sub base 225mm
Capping 200mm
I have been trying to create this in SAC to no avail.
I have modelled the corridor with the UK stock transitional lane but need more information.
Any help appreciated.
Evan
9 REPLIES 9
Message 2 of 10
doni49
in reply to: evanhughes
@evanhughes wrote:
........I have been trying to create this in SAC to no avail.
What kind of problems have you run into?  Can you post a pkt file?  (When you upload a pkt file, rename it so the extension is ZIP).
Maybe post a screen shot of what you're seeing that tells you it didn't work.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Message 3 of 10
Joe-Bouza
Dumb question: Why cant you use the OOTB OutsideLaneSuper assembly?
Your Name
Your Name
Message 4 of 10
Neilw_05
Are you wanting to transition the widths and cross slopes of the lanes or are you wanting to to transition the thickness of the subgrade layers? I think you'll need to provide some clarification.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 5 of 10
evanhughes
in reply to: Neilw_05
I need to transition the lane widths and have all layers do the same.
Evan
Message 6 of 10
sboon
A sketch showing what you're trying to do is usually helpful for this type of question.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
Message 7 of 10
Joe-Bouza
I'll ask again, Why does int an OOTB assembly work?
Your Name
Your Name
Message 8 of 10
Neilw_05
As was mentioned by Joe, some of the subassemblies that come with the product are desigend to stretch to a target element such as an edge of pavement alignment.One such subassembly is the Laneoutsidesuper subassembly.
Each subassembly has a help link associated with it that explains it's capabilities and parameters. So if you see one that has enough pavement layers, examine it's help file to see if it can stretch to a target.
WIN 10 64 PRO
Message 9 of 10
nilesh33
Try this subassembly devloped in SAC 2013
Rename it to .pkt after before importing into Civil 3d.
Nilesh
Message 10 of 10
evanhughes
in reply to: nilesh33
Thanks Nilesh
I could finally see where I was going wrong.
Evan
Rail Community
