I'm not sure what happened but I recently lost my Right-Click options showing Select Similar specifically...is there a function key that disables this use or am I partially crazy? I realize this may be a simple AutoCAD function to fix but you guys are faster than perusing through the book. Any help will be greatly appreicated!
Lieb
Solved by sally.butler. Go to Solution.
Solved by Jeff_M. Go to Solution.
I'm not sure if you mean the whole right-click menu is gone, or just some items are missing from it.
If it's the whole mene, type OP for options, go to the User Preferences tab and check "Shortcut menus in drawing area"
If it's some items missing I think you can edit that in the CUI, but I've never done it.
Mark Green
Working on Civil 3D in Canada
"Options"
Under your options, selection tab, under selections modes make sure the "Noun/verb selection" box is checked on.
Hope this works for you.
SallyB
Lieblaw wrote:The dang Noun/Verb check box!
You should only thank Jeff, because the Pickfirst advice is equivalent of the Noun/Verb one...
Never had that happen before. Easy fix when you know the right question and ask the right people.
Thanks for the solution.
Truly,
