I have a drawing with two feature lines that intersect each other.
Feature line one connects to feature line two. Feature line two has
grading applied to it. I change the grade of feature line one which
affects the connecting elevation of feature line 2. The grading does
not update to reflect the change in elevation. if I change the slope of
a segment in feature line 2 then the grading updates.
is there a way to get the grading to regenerate after a feature line has
been indirectly edited?
David Urban, P.E.
Project Engineer
Pape-Dawson Engineers, Inc.
7800 Shoal Creek Blvd. Suite 253 East
Austin, TX 78757
ph. 512-454-8711
fax 512-459-8867
cell 512-415-1971
durban@pape-dawson.com
***** CONFIDENTIALITY NOTICE *****
This electronic mail transmission may be confidential,
may be privileged and should be read or retained only
by the intended recipient. If you have received this
transmission in error, please immediately notify the
sender and delete it from your system.
