AutoCAD Civil 3D General
TRogers
Message 11 of 23 (1,193 Views)
Re: Exporting Civil 3D Points to Shapefile with "Z" Elevation
04-12-2013 01:06 PM in reply to: rick_JWMA
What coordinate system do you want this in?
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
Active Member
Message 12 of 23 (1,192 Views)
04-12-2013 01:10 PM in reply to: TRogers
UTM with NAD 83 Datum, Zone 10, US Foot, Central Meridian 123d W
TRogers
Message 13 of 23 (1,190 Views)
04-12-2013 01:13 PM in reply to: rick_JWMA
See if this is what you want...if so, I will give you instructions.
*Civil 3DJ*
Todd Rogers
Visit my blog here.
Active Member
Message 14 of 23 (1,187 Views)
04-12-2013 01:16 PM in reply to: TRogers
Yes!,
Exactly what I am looking for.
TRogers
Message 15 of 23 (1,175 Views)
04-12-2013 01:26 PM in reply to: rick_JWMA
Ok.  You were doing the correct procedure at first.
1.  Import points into C3D
2.  Output tab of the ribbon, Export Civil Objects to SDF
3.  Set your projection
4.  MAPIMPORT, select SDF file you just created
5.  Uncheck everything except for Points.  In the Data column click in the cell, then click the ellipsis...
6.  Once in there, toggle the radio button for Create Object Data, the select the button for Select Fields...
7.  Make sure they are all checked, then click OK.
8.  Now you can MAPEXPORT out to a SHP file.
Good luck!!
*Civil 3DJ*
Todd Rogers
Visit my blog here.
Valued Mentor
TerryDotson
Message 16 of 23 (1,168 Views)
04-12-2013 01:34 PM in reply to: rick_JWMA
If you want to avoid jumping through hoops, MapWorks Points contains Point Shapefile Read/Write tools that (in the case of export) creates a shapefile directly from the AECC_POINTS in a quick single step.
TRogers
Message 17 of 23 (1,167 Views)
04-12-2013 01:36 PM in reply to: TerryDotson
Another good program is Global Mapper.
Sent from my Verizon Wireless 4G LTE Smartphone
*Civil 3DJ*
Todd Rogers
Visit my blog here.
Valued Mentor
TerryDotson
Message 18 of 23 (1,154 Views)
04-12-2013 02:53 PM in reply to: TRogers
It is very good, but it doesn't read AECC_POINTS inside Civil3D.
Murph
Message 19 of 23 (1,142 Views)
04-12-2013 04:07 PM in reply to: rick_JWMA
The quickest and easy way I would do it is save the civil3D dwg as an AutoCAD dwg file format. (ExporttoAutoCAD)
Then in that dwg use map export to export to ESRI shp format. When you export open the "Options" tab, click on "Drivers" and check the radio button for 3D.
Simple and no 3rd party or other formats needed other than the dumb down AutoCAD dwg format.
Murph
Supportting the troops daily.
Valued Mentor
TerryDotson
Message 20 of 23 (1,133 Views)
04-12-2013 06:12 PM in reply to: Murph
Simple and no 3rd party ...
Also your procedure gives you no point numbers, no descriptions, etc.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
