Thanks so much for the ides. If I detach the xrefs, I can then insert them as blocks and that seems to work well. The export command no longer creates duplicates, however, it is cumbersome to do with dwgs that have 10 different xrefs. I also tried the buttons in the AEC editor. None of the buttons gave the desired results, but I did learn some new things.
