Going from 2011 to 2012, I just opened my 2011 template and did a saveas for use in 2012, I continued to use the same figure prefix database and SSM template dst, everything worked good. Now with using 2013 I again did a saveas on my template to upgrade the styles, am I able to use the same figure prefix database and dst file or is there a way to upgrade?
You have to copy your figure prefix database from:
C:\ProgramData\Autodesk\C3D 2012\enu\Survey
to
C:\ProgramData\Autodesk\C3D 2013\enu\Survey
then the Survey tool palette will mark them as out of date and you jsut right-click upgrade them.
Mike
