Can you manually create a new cogo point and have it pick up the elevation from a 3D entity that you snap to?
I found this thread from 2010 that says no at that time.
Is this still not possible with C3D 2013?
Solved by Jay_B. Go to Solution.
Works here in 2012 c3d. This is a 3d poly and all shown elev.'s were derived from snapping to the 3d poly.
You're right.
Tried in a new empty drawing, with "Prompt for Elevations" set to Manual.
I failed rule #1 -> always try it in a new empty drawing.... 😞
