AutoCAD Civil 3D General
Distinguished Contributor
Message 11 of 13 (92 Views)
Re: Assembly Label
12-04-2012 11:52 AM in reply to: engrtech
I would like to see this as well.
Was a better method found for 2012?  2013 or wishlist.
I would also like to be able to see where each assembly is used.  The prospector shows if it is used any way to expand where?
I will have to look to see if you can print corridor properties similar to the very long list that was possible in LDD. (It was an awful format.)
*Expert Elite*
Jeff_M
Message 12 of 13 (87 Views)
Re: Assembly Label
12-04-2012 12:40 PM in reply to: annw2
There are some free downloads around with lisp, vba, and dll solutions to aid in adding the Assembly labels. And SIncpacC3D has a builtin command "SPLabelAssembly" to do the same thing, but goes further in in the "SPLabelAssemblySettings" you can opt to have every assembly automatically labeled as it is added to the drawing.
Valued Contributor
C3D_TomR
Message 13 of 13 (77 Views)
Re: Assembly Label
12-04-2012 09:09 PM in reply to: mathewk
The fields update for me if you copy the assembly and mtext object at the same time. Here's a video of the procedure I use. It works in C3D2012 and C3D2013.
http://www.youtube.com/watch?v=sTkAE_1BheE
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
