AutoCAD Forum
pdf underlay layers on/off
2 REPLIES 2
arshadmirza786
3134 Views, 2 Replies
pdf has the same layer state as these were in autocad file
this pdf is  attached as pdf underlay is it possible/ how to on/off the layers of this underlay
2 REPLIES 2
jggerth
in reply to: arshadmirza786
AFAIK, no.  not in Acad.  Essentially in Acad a PDF Underlay is a picture, with very little you can do to it in Cad.  What i'd suggest is setting the layers on/off as desired in Acrobat Pro (not just reader) and saving to a different name, and then attaching that.
In 2015, after selecting the underlay (ATTACHed) .pdf, you'll find "Edit Layers" in the contextual Ribbon.  The type-in command is ULAYERS!
”Boost
