AutoCAD Forum
disable "save as DWG?" when saving a .dxf file
5 REPLIES 5
mikegera
1062 Views, 5 Replies
I work with both .dxf and .dwg files regularly.  When I go to save a .dxf file (_QSAVE), I am always asked if I want to convert to .dwg...it's as if I'm being "persuaded" to switch to .dwg.  Is there a way to disable this?  Thanks.
5 REPLIES 5
rkmcswain
in reply to: mikegera
Try setting your default file type to DXF
Without this set, I only get prompted to save as DWG at the first Qsave and when I close the drawing.
Are you being prompted each and every Qsave?
R.K. McSwain     | CADpanacea | on twitter
mikegera
in reply to: rkmcswain
If I change that setting, won't it basically reverse my problem?
Now that you mention it, I only get prompted on the first _qsave.  However, I have to open up a large number of .dxf files and work on them quickly then close them, so it's still an annoyance.
cadwomen
Hy
so there are tool to make dxf out of dwg as a batch , as long as you go to lunch or every friday evening
cu cw
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
pendean
Perhaps you can create a second profile, so you have one DXF and one DWG, and jump between them based on your workflow?
mikegera
in reply to: pendean
Second profile sounds good.  No idea how to creat or select one, I'll have to invetigate that.
”Boost
