AutoCAD 2013/2014/2015
Alfred.NESWADBA
Message 11 of 20 (418 Views)
Re: Windows 7 crash related to AcDwgFilter16.dll file in Autodesk Shared
10-01-2012 02:07 AM in reply to: staribacherm
>> how do i upgrade to version 19.0.x.x of the AcDwgFilter16.dll?
The way to be sure would be to upgrade your product (ACA).
The way I'm not sure at the moment, but I think there is a good chance, would be to install DWG TrueView 2013 (>>>click<<<)
- alfred -
Alfred NESWADBA
Member
Message 12 of 20 (417 Views)
10-01-2012 02:14 AM in reply to: Alfred.NESWADBA
thanks for the quick reply - i have TrueView 2013 x64 on several other workstations running, but it seems that there is no AcDwgFilter included -> "C:\Program Files\Common Files\Autodesk Shared\" does not contain a folder "AcDwgFilter" like there is on the ACAD Arch. 2012 workstations...
Matthias
DuncanBrannan82
Message 13 of 20 (402 Views)
10-02-2012 12:16 AM in reply to: Alfred.NESWADBA
Volker,
Have you any ideas regarding this issue and why its happening?
At the moment we are having to rename the file to fix this, however as soon as we roll out another product that includes a version of this file, the error will be back with us.
Duncan
Duncan Brannan
If my post was helpful to you, please could you give "Kudos" and/or mark the "Accept as Solution" button(s) below. Thanks in Advance!
Product Support
Volker_C
Message 14 of 20 (391 Views)
10-02-2012 09:23 AM in reply to: DuncanBrannan82
We are attempting to replicate this, but at this time I don't have an answer as to why this may be happening. The AcDWGFilter16.dll version 19.0.55.0.0 is the one we have been using so the issue doesn't appear to version specific. Duncan, you mentioned that this happens after the msgfilt.dll is loaded. Would you please compare your version to mine?
"C:\Program Files\Common Files\Microsoft Shared\Filters\msgfilt.dll 2010.1400.4746.1000".
Cheers!
Volker
Please let us know if your questions have been answered by selecting, "Accept as Solution"
Volker Cocco
Support Specialist
Product Support
DuncanBrannan82
Message 15 of 20 (374 Views)
10-03-2012 01:25 AM in reply to: Alfred.NESWADBA
Hi Volker,
Thanks for getting back to me.
Can you confirm if you have actually replicated the issue as this not just happening to ourselves in the UK but also other regions in the globe.
I can confirm the version of the msgfilt.dll is 2010.1400.4746.1000
Please let me know if there is anything else you need?
Duncan
Duncan Brannan
Product Support
Volker_C
Message 16 of 20 (345 Views)
10-05-2012 09:35 AM in reply to: DuncanBrannan82
Hi Duncan,
I've basically run out of ideas and have been unable to reproduce the problem. At this time I do not have a work around other than renaming the AcDwgFilter16.dll. I will be forwarding the problem to our development team for investigation.
I appreciate all the information you provided,
Volker
Volker Cocco
Support Specialist
Product Support
DuncanBrannan82
Message 17 of 20 (343 Views)
10-05-2012 09:53 AM in reply to: Alfred.NESWADBA
I'm really suprised that you cannot replicate this issue...
I did raise a call through our autodesk Subscription however i havent heard anything but i can assure you that the dll is the source of the problem.
We re planning to rollout AutoCAD 2013 shortly, is there a way we can deploy without sending this file out with the Deployment?
Duncan
Duncan Brannan
Member
Message 18 of 20 (324 Views)
10-08-2012 12:27 AM in reply to: Volker_C
Hi Volker,
maybe i've got another idea for you... Because this is often a problem with different systems around my company - could it be possible, that the problem occurs only with different codepages/character-sets? Nearly all of our drawings and emails contain cyrillic and/or other non-latin characters... And could non-unicode characters in combination with a wrong non-unicode language of Windows be a problem too!?
Best regards,
Matthias
Product Support
Volker_C
Message 19 of 20 (314 Views)
10-08-2012 09:03 AM in reply to: Alfred.NESWADBA
That's a very good thought. If I could get a sample of a problematic embedded dwg in a msg file that would help.
Cheers,
Volker
Volker Cocco
Support Specialist
Product Support
DuncanBrannan82
Message 20 of 20 (301 Views)
10-08-2012 02:31 PM in reply to: Alfred.NESWADBA
This is an ongoing issue in the UK and Australia as far as i;m aware. From what we can see it is any DWG inside an MSG file.
I even managed to create the issue from a blank DWG.
Duncan
Duncan Brannan
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
