AutoCAD 2013/2014/2015
Valued Contributor
Message 1 of 7 (1,134 Views)
Undo Overflow
1134 Views, 6 Replies
07-04-2012 07:48 AM
New one on me
AutoCAD Map 3D 2013
DWG version 2013 - file size 6562kb
Windows 7 Professional SP1 64bit
Intel Xeon 3.10ghz
8gb RAM
Member
Message 2 of 7 (921 Views)
Re: Undo Overflow
10-29-2012 02:12 PM in reply to: Neil47
I've been getting this message ever since i upgraded to Acad map 3d 2013.  it gets particularly annoying when using orthophotography.  i've tried all the guesses as to fixing it but nothing works.  just letting y'all know it's happening a lot.
oceanside
Message 3 of 7 (884 Views)
Re: Undo Overflow
11-14-2012 01:30 PM in reply to: Neil47
I have someone in the office having the same problem.  I told them to save & restart.  When they did this, they did not receive that message.  Undo acted like always.  I can't figure what's happening.
the best is at the beach!
Active Member
Message 4 of 7 (816 Views)
Re: Undo Overflow
12-06-2012 05:49 PM in reply to: Neil47
I've been having this problem also since upgrading to Autocad Map 2013.  And before I get that message, undo doesn't really work right.  I've tried the off and then on thing.  Also tried closing out and re-opening. But I'd like to actually solve it.  Does anyone know how to set it differently so it works like it used to in 2011?
Valued Mentor
skintsubby
Message 5 of 7 (810 Views)
Re: Undo Overflow
12-06-2012 11:27 PM in reply to: jaspergeographics
Is "UNDO" "AUTO" set to ON?
Active Member
Message 6 of 7 (796 Views)
Re: Undo Overflow
12-07-2012 11:24 AM in reply to: Neil47
Yes it is for now and today it is behaving, haven't had the overflow problem yet.  Once the problem happens, though, I'll check the auto status again.
Active Member
Message 7 of 7 (746 Views)
Re: Undo Overflow
12-11-2012 02:12 PM in reply to: skintsubby
So I get that overflow message again (similar to the image that began this thread) and I do the off and then on again trick that the message says to do, but it obviously does not clear the file because shortly thereafter I get another message and this one has a larger number of bytes that it says are there so that undo will be disabled when it reaches an even nearer threshold.  To turn it off I typed undo, clicked on auto, clicked on off then did the same to turn back on.  That turns auto undo off and on---is there a way to turn the whole undo command off and then on?
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
