AutoCAD 2013/2014/2015
Active Contributor
Message 1 of 7 (1,375 Views)
Stopping the mbutton from zooming all extents
1375 Views, 6 Replies
01-22-2013 02:41 AM
I usually use my mbutton to pan dwg. Just started using AutoCAD 2013 and I notice it zoom extents everytime I press the mbutton (the middle scrollwheel button). How do I disable this zoom extents?
One more thing, how do I disable the annoying auto complete whenever I type in a command? It seems to be slowing my work flow.
Kiarian
Alfred.NESWADBA
Message 2 of 7 (1,365 Views)
Re: Stopping the mbutton from zooming all extents
01-22-2013 04:43 AM in reply to: kiarianc
to your first question: a ZOOM EXTENTS by default is ony done when you double-click the mouse-wheel-button. Is it possible that you reconfigured your mouse-wheel-button in your mouse driver? (E.g. to do a single click in Windows-Explorer to enter a directory?)
>> [...] I disable the annoying auto complete
You have a small symbol besides the command-line-window for setting sysvars for commands (and command-window).
And if you enter in the command-line AUTOCOMPLETE ==> have you looked to the options? :smileywink:
- alfred -
Alfred NESWADBA
Active Contributor
Message 3 of 7 (1,358 Views)
01-22-2013 05:01 AM in reply to: Alfred.NESWADBA
Thanks for that. Autocomplete is the option I was looking for.
Re. the first problem, no, this is happening everytime I hold the scroll wheel to pan. Zooms extents everytime. When I type in mbuttonpan, it's set to 1. This should be fine, and if I press and hold, it sometimes acts as pan. Then when I try to pan again, bang... it's set to zoom extents again. Very annoying!
Kiarian
Alfred.NESWADBA
Message 4 of 7 (1,353 Views)
01-22-2013 05:28 AM in reply to: kiarianc
Some weeks ago we had a similar problem, the solution there was to change the mouse (wait until your neighbourh does a coffee-break and then hurry up :smileywink:)
At least try it, and if that also does not work try another mouse-type/-vendor to make sure it's no driver setting (even it's not happening every time).
. alfred -
Alfred NESWADBA
pendean
Message 5 of 7 (1,351 Views)
01-22-2013 05:31 AM in reply to: kiarianc
Agree with Alfred, your hardware is the problem (mouse button), we've experienced the same here over the years.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Contributor
Message 6 of 7 (1,343 Views)
01-22-2013 05:45 AM in reply to: pendean
Thanks for the replies. Mouse hardware doesn't seem to be the problem. Working from home. Just tried 3dsMax just to double check. Scroll button is working fine to pan. Scroll button works fine when pressed to rapid scroll internet page as well. Hmmmm. Strange.
Edit. You could be right. The scroll wheel is feeling a bit tetchy.
New Member
mbyrd
Message 7 of 7 (1,027 Views)
06-02-2013 11:00 AM in reply to: kiarianc
Hi. I've been struggling with my middle mouse button on my Logitech M505 recently as well. I'm accustomed to using the middle wheel as a button for panning and it seemed that recently AutoCAD 2013 was acting like it was receiving comflicting instructions for this action. In other words, it would pan, stutter, and try to zoom or select.
Anyway, I solved it by going to Device Manager and taking a look. The list of mice was much longer than it should have been. I uninstalled all of them (and deleted the driver when given the option) and used my track pad (i'm on a laptop) to then go to the Unifying software and repair my mouse. After that Device Manager still shows three HID-compliant mouse listing s but no Logitech listings (there were four of those previously). Now panning works as before.
I suspect I'd switched receivers and mice a few times too often and ended up with multiple comflicting drivers running simultaneously.
Hope this helps someone.
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
