I am trying to do screen recordings for my students using screencast o matic. I even have the pro version and downloaded it to the computer. The program works fine when recording my desktop, word docs., etc, but as soon as I try to record my AutoCAD 2014 screen the mouse lags. I've tried it on both a Dell 780 PC and a Lenovo tablet and have the same problem.
I have also tried CamStudio. I had problems here too. I get the common error message when saving the recording... "file creation error. Unable to rename/copy audio file". After fixing that problem by changing save locations and other settings like the number of frames per second and playback rate, my voice does not match up with the video recording. I've tried adjusting the numbers but nothing seems to work.
FYI, I need to upload videos to YouTube when done
Does anyone have any suggestions? Thanks!
Solved by DarrenP. Go to Solution.
have you looked at autodesks tool called Project Chronicle
https://beta.autodesk.com/callout/?callid=B1507125C2A64E64971F348EB815C3C0
some examples: https://chronicle.autodesk.com/
don't know if you can upload to youtube with this
DarrenP
Chronicle hosts the material on Autodesk servers, so youtube would not be an option
At a guess, the video in the PC and /or tablet aren't able to handle Acad and the screen capture - possibly try turning off hardware acceleration in Acad (or turn it on if it's off)
