After doing a purge of unneccesary layers, my drawing file is no longer able to use quick select normally. With nothing selected, the quick select window doesn't allow me to select any properties with object type set to multiple. If I set the object type to something more specific, the properties display normally:
Audit does not fix the problem. Why does this occur, and is there any way to resolve this without have to copy/paste into a new drawing?
Solved by chadcross. Go to Solution.
This issue has come up again, this time it happens only if I delete two empty text objects. I can change their style, add contents, change layer, etc. but as soon as I delete them, quick select no longer works. If I copy everything but the two text objects to another drawing, quick select does not work. I'm literally stuck with these two blank text objects, and I don't understand why.
I can email the file if someone is willing to take a look...
Can you attach the drawing here? (use the Attachments button in the Reply window) Also for testing purposes, can you specify which AutoCAD version you're using.
