Autodesk,
Please bring back the option (we used to have) of customizing the color outside of the paperspace boundry.
I have always used this feature as a check and balance to verify that drawing layouts have been set up correctly. I just found out that several junior drafter/designers have no clue to set up up sheets and have been faking things. Files got sent to an outside client and they are wondering what is up with people because they are not plotting correctly. Sure enough, the area of the sheets are 22" x 34" but the actual sheet size setting in the page setup is 11" x 17". The young workers don't have the boundary turned on so everything is black and they have no idea how they are messing things up because everything looks good to them.
The non optional light grey is so aggrevating (in 2014). Most people use a black background with a white crosshair/pickbox setup which get lost outside of the sheet boundry. I am always using the outside area for bringing in notes and references as blocks.
Please bring back this color change option as a patch for current versions.
Thanks!
