Hello all.
I am a new user so excuse me for this question: I want to make a file for applying simulation in CFD simulation 2014 so for this reason i decided to make *.prt file in autocad but i cant find an option to make part or assembly files in autocad 2014 so i would glad for any solution.
thx...
there is no option to make a .prt file in AutoCAD. Not sure what else to tell you?
looking at the 2014 help, it says these cad formats are supported:
You can create a new design study by directly opening a geometry or CAD file. This capability supports the following CAD and geometry file types:
So, either use Inventor or one of the other listed applications.
@AlexG402 wrote:
Can someone help me with this issue, i am stucked with my project...
Thx
In AutoCAD run the ACISOUT command (will create a *.sat) file.
Not sure how this relate to the thread title?
thank you for the answer... so the best solution is to use invertor and invert my draw file to part file for using CFD simualtion?
@AlexG402 wrote:
...so the best solution is to use invertor and invert my draw file to part file for using CFD simualtion?
Where did you see that as a possible solution?
If you already have the work done - simple ACISOUT to save it in a *.sat file format that CFD will open.
Yes, you should probably be using Autodesk Inventor (not invertor?) from the start, but since you already have the work done simply save it as *.sat.
