AutoCAD Forum
How to remove mesh from 3d Object
4 REPLIES 4
BeKirra
8386 Views, 4 Replies
I prefer to use "Realistic" visual style.
Please see the attachment.
Thanks for your help.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
4 REPLIES 4
nestly2
in reply to: BeKirra
In the Visual Styles manager (VISUALSTYLES), select "Realistic" then look under "Edge Settings"  You can choose between Facet Edges, Isolines, and None.  The number of Isolines is controlled by the ISOLINES variable, which by the way is 20 in your drawing... AutoCAD default is 4, so "someone" not only wanted those lines, they wanted 5x more than normally displayed  😉
(BTW,  REGENALL may be required to update ISOLINES)
BeKirra
in reply to: nestly2
Very nice.
"In the Visual Styles manager (VISUALSTYLES), select "Realistic" then look under "Edge Settings"  You can choose between Facet Edges, Isolines, and None."
Is this setting saved in drawing or in registry that makes every drawing with the same appearance?
Thanks.
X² + Y² = C²
nestly2
ISOLINES is stored in the drawing, as are Visual Styles.   Update your Template (.dwt) according to your preference.
BeKirra
Thanks.
X² + Y² = C²
”Boost
