I don't know how to fix it.
PICKFIRST, PICKADD, DRAGMODE didn't work for me.
Help pls?
Solved by Patchy. Go to Solution.
I'm using 2014 on Windows 8.
The file is in 2013 format (from my friend) but I do my works just fine few days ago- until today I open the file and try edit someting but I can't click & drag.
It appears only to this file. I tried opening other files and they can be click & drag
I don't understand your solution. Doesn't _la bring up the layer manager?
It should be -la not _la but the OP got the gist of it and figured it out.
