unhandled access violation reading 0x0010 exception at f8227b12h. its only doing it with one drawing. what could cause this?
welcome @forums.autodesk.com !
When does that exception occur? When opening the drawing or when starting a specific command or ...?
If it's specific to one drawing you can start AutoCAD, run command _RECOVER and select that drawing. That initiates a repair-process for that drawing, maybe there are some problems in the file.
Good luck, - alfred -
Hello
+1 with Alfred - First _RECOVER
You could install the SP 1 for ACAD 2013 :
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22264351&linkID=9240618
Maybe it could help you ...
Bye, Pat
Patrice BRAUD
Also try starting a new empty (no template) drawing and then insert your problem drawing as a block, then explode.
If you have access to AutoCAD MAP, there are ways to import portions of "bad" drawing. Post back if this is an option for you.
