win 8.1 is not a supported platform for acad 2014. If you want to stick with that OS, then you really need to migrate to 2015 - which is supported.
Alternatively, upgrade your OS to Win7. that's still available for purchase from many vendors.
Ok how do I download that driver? I really don't want to install Windows 7 if I don't have to.. and I tried to change that value but all it does is make the hatch option come up first but it's still freezing. I tried to use hatch in a new file and it works just fine..I'm thinking a currupt file but I'm not ready to loose all the work I've done.
Updated drivers will have be retrieved from your PC vendor, or the Card manufacturer.
If it's just one drawing, you can run AUDIT on the file, and see if that identifies any problems. Also run the PURGE command, and then -purge with the R option to eliminate regapps.
And finally, you can Wblock the drawing out to a new file. That hopefully will clear it up without losing the entire kit and kaboodle.
