Not able to create new tab with Ctr+mouse drag. Why did you removed this option in 2015??? Now we have to creat new tab with extra steps. It was so easy before, so why did you took it from AutoCAD 2015????
Yep. The guys a Autodesk did it again. On an active layout tab, Ctrl+Drag doen't work as it did.
There's no rule that says you have to use AutoCAD 2015. Stay with an eariier release (version).
Be sure to report this bug to Autodesk:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
I reported it yesterday, but the more users that send complaints in, the more likely it is to be fixed.
Also, if you are a subscription user, you can report through the Subscription Center as well.
