AutoCAD Forum
AutoCAD 2015: Border Glitch
22 REPLIES 22
Message 1 of 23
nrz13
3846 Views, 22 Replies
I'm setting AutoCAD 2015 up on multiple machines and I've noticed that on single-monitor setups there's a glitch on the right-hand side of the window when it is maximized.  The glitch shows up as either a blue or gray and black striped border on the right side only -- see attachments.
For multi-monitor setups the glitch is not present.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
22 REPLIES 22
Message 2 of 23
pendean
in reply to: nrz13
Glitch? It's a border/edge 😞
Message 3 of 23
nrz13
in reply to: pendean
That's not supposed to be there...
Borders should only show up when it is in windowed mode, not maximized mode.  No previous AutoCAD version or any other windows program I've ever seen exhibits this behavior.
Message 4 of 23
jggerth
in reply to: nrz13
I've got a 2011 session maximized at the moment,and it's showing a border on both left and right edges - though less apparent on the left side.  appears to be about the same number of pixels as your images show.
Message 5 of 23
nrz13
in reply to: jggerth
Interesting.  I've never seen that happen before and I definitely would have noticed it because it would drive me nuts.  Thankfully, the problem doesn't show up for me on my multi-monitor setup.  I suppose that could be the result of a video card issue with AutoCAD, which would make sense since we're having video card issues right now.
Message 6 of 23
in reply to: nrz13
I have this border in both AutoCAD 2012 and 2014 versions when maximized even when using multiple monitors. Although not as wide/pronounced as the ones in your 2015 screen shots.
See attached screen shots. May have to zoom in to see them.
Message 7 of 23
pendean
in reply to: nrz13
No such border on my Laptop or Desktop with R2015 or LT2015.
What video card do you have where this is happening?
Message 8 of 23
nrz13
It was happening on a rig with the same specs as mine (except only one monitor, 1920x1200):  See signature below.
Video Card is AMD FirePro V4900.
Message 9 of 23
Ron-C
in reply to: nrz13
2014 Maybe it's a "Windows setting " ?  I don't have it on eith desktop or Laptop Windows 7 enterprize
Not on desktop 2013 either !
Ron
Message 10 of 23
nrz13
in reply to: Ron-C
Well, there's obviously more to this than I originally thought and it's clearly not an issue exclusive to 2015.  Still, it shouldn't be there.  As far as long-time AutoCAD bugs to fix go, I'm guessing this would be pretty low on everyone's list (including mine), but it would be nice to see things like that being fixed.  They obviously spent a lot of time re-tooling the interface in 2015.  I think a little time devoted to fixing this issue wouldn't have been unreasonable, if they even knew about it in the first place.
Message 11 of 23
w64bit
in reply to: nrz13
This is worse than I thought.
1. On Win 7, the main window is not fully extended on maximized view. The desktop background can be seen near the AutoCAD window border.
This border is present on one, two or three edges.
I attached:
- 1 screenshot from Win 7 aero theme.
(you can see near Copy button a part of letter "A". It's from a desktop shortcut !!! Also, the toolbar buttons are cropped).
- 2 screenshots from Win 7 classic theme.
2. On Win 8.x, even if the program is started maximized, the main window is displayed sometimes beneath the statusbar.
This must be fixed very fast because it is very annoying.
Message 12 of 23
Ron-C
in reply to: w64bit
I have a similar problem with the sides of the maximized screen  on Autocad 2015
Sometimes I can see thru to the desktop, other times I can see what appears to be another set of Toolbars, but
actually it is not. (Not selectable or moveable(See screen shoot
Windows 7 enterprize 64bit
6 gig
AMD Firepro V3900 (With latest driver)
Ron
Message 13 of 23
pendean
in reply to: nrz13
Sadly, "annoying" is not enough of a condition for Autodesk to drop everything and address it. It may or may not be patched with the next update sooner or later if ever. Reporting here is informative to other users but not a way to get Autodesk's attention either.
Report your issue through your subscription portal.
Message 14 of 23
in reply to: nrz13
I have the same problem with Civil 3D 2015. I'm with AMD HD7790 video. Is anyone with nVidia have a problems ? I'm not sure, but here at this moment only user with AMD/ATI report problems. Sorry for my bad english.
Message 15 of 23
w64bit
I am on Quadro 4000.
Message 16 of 23
in reply to: nrz13
Well, SP1 is here and there are no changes. The problem still exist... Thank you AUTODESK 😕
Message 17 of 23
reply
I have this problem too.The problem seems to be related to using windows 'classic' theme. When I switch to a newer theme (Win 7 Basic / Aero),the problem is fixed... but I won't!
Message 18 of 23
N.R.Hobson
in reply to: reply
the command CLEANSCREENON seems to "fix" it.
Message 19 of 23
nrz13
in reply to: N.R.Hobson
CLEANSCREEN just adds a border all the way around, so I'm not sure that's a good solution either.  Plus, you lose your palettes with that.
Message 20 of 23
Ron-C
in reply to: nrz13
Problem still exisits in 2016
Seems to me it started with 2015 as I did not have it in 2014.
Did'nt  autodesk change their "Display Engine" (Whatever it's called) begining with 2015 ???
This is when I started seeing the borders (See thru to desktop) when Maximised.
Ron
”Boost
