AutoCAD Forum
ARG Export Not Saving[2014
8 REPLIES 8
Message 1 of 9
Oli
393 Views, 8 Replies
Hi All, I'm trying to create an ARG file, I've customized the file locations, colours etc... Applied and then Exported. However when I Import the profile and Set Current everything goes back to defaults, and yet when I click back on to the one created its all good. Any ideas why the Export isn't working? I've tried it in AC 2014 & 2012 I'm hoping I've missed something! Thanks
Tags (2)
8 REPLIES 8
Message 2 of 9
Alfred.NESWADBA
in reply to: Oli
what product & version & servicepack did you use when you exported your profile, what product & version & servicepack did you use to import that profile?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 3 of 9
Oli
in reply to: Alfred.NESWADBA
AutoCAD 2014 - Service Pack 1 for import and export Thanks Oli
Message 4 of 9
Alfred.NESWADBA
in reply to: Oli
So to reproduce I tried: added a path to the support paths, applied the changes, exported the profile, closed AutoCAD, opened AutoCAD, imported this ARG-file to a new profile-name, made this new profilename active ... and now you lost the added support-path? Sorry, I can't reproduce that, for me that woked.
To get more close to the problem we have to start at:
a) is the export defect
b) is the import defect
...therefor open the ARG-file in an editor (notepad++ or similar) and see if the changes, in the above sample the path added, are present in the ARG. So we know where to search, a) or b)
- alfred -
Alfred NESWADBA
Message 5 of 9
Oli
Looking at the ARG file it looks like all the paths are there so it must be an import defect Oli
Message 6 of 9
Alfred.NESWADBA
in reply to: Oli
can you upload the ARG file here? Maybe it's necessary to ZIP it.
And just to make sure: you are sure you gave the imported profile a new name ... and that new name is then listed in the list of profiles.
And a second check: are you sure you have enough permissions to rewrite the registry (as the import needs)?
- alfred -
Alfred NESWADBA
Message 7 of 9
Oli
Hi Alfred, Here's the file, I've tried changing the name, and it does list and I set current. it could be the locations that I'm mapping to, but i don't think that would affect the colours scheme etc. I'm an admin on my pc so i would hope that i could write permissions, but i'll have a double check . O
Message 8 of 9
Alfred.NESWADBA
in reply to: Oli
>> Here's the file
Not here. Have you zipped it?
Not necessarily, try to start AutoCAD via right-click and option "Start as administrator", then you have your full permissions.
And please let me know what detail you modified so I can look to that after importing it.
- alfred -
Alfred NESWADBA
Message 9 of 9
Oli
Just had ago by run as admin and its worked fully! didn't think that made a difference if you were an admin Amazing Thank you! Oli
”Boost
