AutoCAD 2010/2011/2012
New Member
Message 1 of 14 (365 Views)
What the heck is up with this
365 Views, 13 Replies
11-29-2012 10:02 AM
What kind of kindergarten technology is this that given the boundary limits of a solid in the form of a 3D wireframe, we cannot create a solid model?!?!?!
Message 2 of 14 (353 Views)
Re: What the heck is up with this
11-29-2012 11:21 AM in reply to: rgilroy2010
Works fine here.
Can you attach the file here that exhibits this behavior?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
GrantsPirate
Message 3 of 14 (344 Views)
11-29-2012 12:05 PM in reply to: rgilroy2010
If you are using the extrude command note at the command line there is a MOde option, this will set a surface or solid until you change it again.
New Member
Message 4 of 14 (338 Views)
11-29-2012 12:20 PM in reply to: GrantsPirate
I am not new to autocad and can model quite well. I do not have it in a wireframe setting, the complaint is for the fact that when one needs to create a model that is not simple enough, or symmetric enough to just extrude, one has to go through the process of digitally "carving" the shape out of a block billet, and then utilize a multitude of reg, ext, union, subtract, and intersecting cut commands to end up with a part. This is not an engineering procedure, that is an artist's procedure. It would be more convienient to have a feature where you define 3D limits using wireframe (ie lines that are set as boundaries) and then have a 3D fill command to convert it into a solid. After all, this is a software that is well know in the world of engineering.
Message 5 of 14 (320 Views)
11-29-2012 01:55 PM in reply to: rgilroy2010
Attach the file here.
Message 6 of 14 (308 Views)
11-29-2012 03:21 PM in reply to: rgilroy2010
This procedure works on a set of lines (wireframe) created from a box with xedges.
For each face, (lines in 2 directions) use network command.  After you have created a watertight enclosure (overlaps permitted), then use surfsculpt to create the solid.
Message 7 of 14 (264 Views)
12-01-2012 04:40 AM in reply to: rgilroy2010
Can you create an example and attach it here?
Member
Message 8 of 14 (132 Views)
Re: Attached is an example of lines I would like to convert to a 3D Solid
09-13-2013 11:44 AM in reply to: rgilroy2010
Some 3D solids might be created faster if I was able to convert the attached 3-dimensional lines to a 3D solid.  Is it possible?  Please see attached.
Patchy
Message 9 of 14 (127 Views)
09-13-2013 11:52 AM in reply to: akostenko007
Yes possible.
Pedit the bottom part (join them)
Same to the top
Then LOFT
Member
Message 10 of 14 (113 Views)
09-13-2013 12:20 PM in reply to: Patchy
Patchy,
Thank you for a quick reply.  But I get an error using a Loft command:  "At least two profiles must be selected".  I do have two profiles - please see attached.
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
