AutoCAD 2010/2011/2012
Message 11 of 12 (262 Views)
Re: Student Plant 3D - Complaint
02-08-2013 06:13 AM in reply to: hoodedmarcantonio
Did you install with UAC and anti-virus turned off?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
New Member
Message 12 of 12 (136 Views)
04-05-2013 02:41 AM in reply to: JDMather
Hi, I get exactly the same problem, I've got the 32bit student version and haven't been able to use it yet because I get this (see below) when I try to make a new drawing.
I found this explanation - http://www.lazcad.com/autocad-pid  -but can't figure out how to implement the solution, any ideas?
Dom
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.Runtime.InteropServices.COMException (0x80200033): Filer error
   at Autodesk.AutoCAD.Interop.AcadDocumentsClass.Add(Object TemplateName)
   at Autodesk.ProcessPower.ProjectManagerUI.frmNewDWG_Revised.CreateAndSaveNewDrawing()
   at Autodesk.ProcessPower.ProjectManagerUI.frmNewDWG_Revised.btnOK_Click(Object sender, EventArgs e)
   at System.Windows.Forms.Control.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Button.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.0.30319.296 (RTMGDR.030319-2900)
    CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
AdApplicationFrame
    Assembly Version: 0.0.0.0
    Win32 Version: 3.2.23.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/AdApplicationFrame.DLL
msvcm90
    Assembly Version: 9.0.30729.6161
    Win32 Version: 9.00.30729.6161
    CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_31a54e43/msvcm90.dll
Acdbmgd
    Assembly Version: 18.2.0.0
    Win32 Version: 18.2.51.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/AcdbMgd.DLL
System
    Win32 Version: 4.0.30319.1001 built by: RTMGDR
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
AdWindows
    Assembly Version: 3.2.23.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/AdWindows.DLL
PresentationFramework
    Win32 Version: 4.0.30319.298
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
WindowsBase
    Win32 Version: 4.0.30319.298 built by: RTMGDR
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationCore
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
System.Xml
    Win32 Version: 4.0.30319.233 built by: RTMGDR
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
PresentationFramework.Luna
    Win32 Version: 4.0.30319.1 built by: RTMRel
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Luna/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Luna.dll
System.Drawing
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Acmgd
    Win32 Version: 18.2.51.0.1
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/Acmgd.DLL
System.Core
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Configuration
    Win32 Version: 4.0.30319.1 (RTMRel.030319-0100)
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
AcWindows
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/AcWindows.DLL
AcCui
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/AcCui.DLL
PresentationFramework.Aero
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
AcWindows.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/en-US/AcWindows.resources.DLL
PnPDataLinks
    Assembly Version: 6.0.0.0
    Win32 Version: 6.0.39.00
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnPDataLinks.DLL
PnPCommonArx
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/pnpcommonarx.arx
PnPProjectManager
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnPProjectManager.arx
PnPProjectManagerMgd
    Assembly Version: 6.0.39.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnPProjectManagerMgd.DLL
PnPCommonMgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnPCommonMgd.DLL
PnIDMgdInternal
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnIDMgdInternal.DLL
PnIDUIMgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnIDUIMgd.DLL
PnPCIP
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnPCIP.DLL
PnIDCIP
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnIDCIP.DLL
PnPProjectManagerUI
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnPProjectManagerUI.DLL
PnPProjectManagerUI.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/en-US/PnPProjectManagerUI.resources.DLL
PnPRevisionCloud
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnPRevisionCloud.DLL
XDbReferenceManagerArx
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/XDbReferenceManagerArx.DLL
XDbReferenceManagerArx.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/en-US/XDbReferenceManagerArx.resources.DLL
PnIDMain
    CodeBase: file:///c:/program%20files/autodesk/autocad%20p%26id%202012%20-%20english/pnidmain.arx
ContextualTabSelectorRules
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/AcWindows.dll
PnIDWorkspace
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnIDWorkspace.DLL
    Win32 Version: 4.0.30319.1002 built by: RTMGDR
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
WindowsFormsIntegration
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
ManagedMC3
    Assembly Version: 5.8.0.0
    Win32 Version: 5.8.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/ManagedMC3.DLL
Accessibility
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
PnIDProjectPartsMgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnIDProjectPartsMgd.DLL
PnPDataObjects
    Assembly Version: 1.0.4206.15350
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnPDataObjects.DLL
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Autodesk.AutoCAD.Interop/18.2.0.0__eed84259d7cbf30b/Autodesk.AutoCAD.Interop.dll
Autodesk.AutoCAD.Interop.Common
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Autodesk.AutoCAD.Interop.Common/18.2.0.0__eed84259d7cbf30b/Autodesk.AutoCAD.Interop.Common.dll
ci0m01kq
jrb3xux4
PnP3dProjectPartsMgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnP3dProjectPartsMgd.DLL
PnP3dDataLinkManager
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnP3dDataLinkManager.DLL
PnP3dOrthoProjectPart
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnP3dOrthoProjectPart.DLL
044ymin1
System.Data
    Win32 Version: 4.0.30319.237 (RTMGDR.030319-2300)
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
PnPSQLiteEngine
    Assembly Version: 1.0.4206.15360
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnPSQLiteEngine.DLL
System.Data.SQLite
    Assembly Version: 1.0.65.0
    Win32 Version: 1.0.65.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/System.Data.SQLite.DLL
System.Transactions
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
Microsoft.VisualC
    Assembly Version: 10.0.0.0
    Win32 Version: 10.00.30319.01
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualC/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualC.dll
System.EnterpriseServices
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
System.Numerics
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
vfomqhkf
thvcyghc
dyw3bgu1
arfmax0s
pnnlvcqx
PnP3dPartsRepository
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnP3dPartsRepository.DLL
PnP3dConnectionManager
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnP3dConnectionManager.DLL
nm0az2jw
kjfkodz3
v5dqncad
owb03bnj
032vecdh
vwhoqof5
PnIDProjectParts
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnIDProjectParts.Arx
PnIdGuiUtils
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnIdGuiUtils.DLL
PnIDGUIUtilMgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnIDGUIUtilMgd.DLL
PnPCommonUIMgdCs
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnPCommonUIMgdCs.DLL
PnPCommonUIMgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnPCommonUIMgd.DLL
AcTaskDialogs
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/AcTaskDialogs.DLL
AcTaskDialogs.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/en-US/AcTaskDialogs.resources.DLL
PnPWelcomeManager
    CodeBase: file:///c:/program%20files/autodesk/autocad%20p%26id%202012%20-%20english/pnpwelcomemanager.arx
PnPWelcome
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnPWelcome.DLL
PnPCommonDbxMgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnPCommonDbxMgd.DLL
PnPWelcome.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/en-US/PnPWelcome.resources.DLL
AcLayer
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/AcLayer.DLL
AcLayer.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/en-US/AcLayer.resources.DLL
AcButterflyExt
    Assembly Version: 1.0.0.23
    Win32 Version: 1.0.0.23
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/AcButterflyExt.DLL
AcButterflyExt.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/en-US/AcButterflyExt.resources.DLL
UIAutomationProvider
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
PnIDDwgValidation
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnIDDwgValidation.DLL
PnIDDwgValidation.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/en-US/PnIDDwgValidation.resources.DLL
PnPValidation
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnPValidation.DLL
frt5riuj
r02bf42j
pz4o2jql
54uwr5gd
uibmx0ak
00qe2h14
1g3ebi14
wntnl4u2
AcDialogToolTips
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/AcDialogToolTips.DLL
AcDialogToolTips.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/en-US/AcDialogToolTips.resources.DLL
AcCommandToolTips
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/AcCommandToolTips.DLL
AcCommandToolTips.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/en-US/AcCommandToolTips.resources.DLL
dyhhe42h
tmv0qkmv
3y33i4o3
3qavfmii
xxw3gve2
0dpcv55m
ge0ucpj5
ctyjohva
PnPDataGrid
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/PnPDataGrid.DLL
PnPDataGrid.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20P%26ID%202012%20-%20English/en-US/PnPDataGrid.resources.DLL
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
