AutoCAD 2010/2011/2012
Message 1 of 3 (455 Views)
Match Attribute Values in the Same Block
455 Views, 2 Replies
01-04-2013 08:17 AM
Does anyone know how to get attribute values to match in the same block? In my titleblock have the clients name displayed a couple of time in the block. I want to be able to change the clients name in one spot and have it change in the other. I have tried to use fields but the field will only display the default value of the attribute.
Distinguished Mentor
Moshe-A
Message 2 of 3 (425 Views)
Re: Match Attribute Values in the Same Block
01-05-2013 03:02 AM in reply to: caramelja
Caramelja,
1. you are right when a field is referencing attribute value it only copy it's default value. to me it looks
   like a bug (but it's better autocad should comment on this)
2. you got lucky today i have wrote a lisp to answer your question
    it call ATVP (Attribute Value Populate) copy and paste this code into
    a lisp file call it ATVP.LSP
   in order it to work you need to modify the next two lines with your own tags name
   (setq source_tag "tag0")                      ; replace "tag0" with your source tag name
   (setq target_tag^ '("tag1" "tag2" "tag3")); replace ("tag1" "tag2" "tag3") with your own target tags name
   these two lines are locate right after this line:
   (defun c:atvp (/ source_tag ... )
   now save it and load it and key in ATVP command
cheers
moshe
(vl-load-com); load ActiveX
(defun get_attrib_value (ename tagName / sub-ename sub-elist flag attval)
 (setq sub-ename (entnext ename) sub-elist (entget sub-ename))
 (while (and (not flag)
	     (/= (cdr (assoc '0 sub-elist)) "SEQEND")
  (if (eq (strcase (cdr (assoc '2 sub-elist))) tagName)
   (setq attval (cdr (assoc '1 sub-elist)) flag t)
   (setq sub-ename (entnext sub-ename) sub-elist (entget sub-ename))
 ); while
 attval
; Attribute Value Populate
(defun c:atvp (/ source_tag target_tag^ esel ename elist source_value sub-ename sub-elist)
 (setq target_tag^ '("tag1" "tag2" "tag")); replace ("tag1" "tag2" "tag3") with your own target tags name
 (if (setq esel (entsel "\nSelect block: "))
  (progn
   (setq ename (car esel) elist (entget ename))
   (if (and (= (cdr (assoc '0 elist)) "INSERT")
	    (= (cdr (assoc '66 elist)) 1)
    (progn
     ; ensure uppercase
     (setq source_tag (strcase source_tag))
     ; ensure uppercase
     (setq target_tag^ (mapcar
	      		'(lambda (tagName)
	        	  (strcase tagName)
	     		target_tag^
		       ); mapcar
     ); setq
     ; get source tag value
     (setq source_value (get_attrib_value ename source_tag))
     (if (or (not source_value) (/= source_value ""))
      (progn
       (while (/= (cdr (assoc '0 sub-elist)) "SEQEND")
	(if (and (/= (strcase (cdr (assoc '2 sub-elist))) source_tag)
		 (member (strcase (cdr (assoc '2 sub-elist))) target_tag^)
	 ; populate source attribute value
         (entmod (setq sub-elist (subst (cons '1 source_value) (assoc '1 sub-elist) sub-elist)))
	); if
       ); while
      ); progn
      (progn
       (vlr-beep-reaction)
       (princ "\nsource tag is not found or it's empty value.")
     ); if
    ); progn
    (progn
     (vlr-beep-reaction)
     (princ "\nentity selected is not a block or does not contain attributes.")
   ); if
  ); progn
 ); if
 (princ)
Message 3 of 3 (371 Views)
01-07-2013 07:15 AM in reply to: caramelja
Thanks, I will give it a shot. It has been a long time since I have used Lisp so I will need to refresh my memory.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
