AutoCAD 2010/2011/2012
steven.carlson
Message 1 of 4 (848 Views)
FATAL ERROR : Unhandled e06d7363h Exception at fdaecacdh
848 Views, 3 Replies
02-05-2013 01:20 PM
I am getting this error when double clicking on an object when using CADWorx 2010 inside of Autocad 2010.
This error is quite consistent and can sometimes present as the following with out an FATAL ERROR:
Exception in cadworxplant2010.arx ARX Command
Uhandled Exception E06D7363 (e06d7363h) at address FDEB0CACDh
we are using Win7 - 64bit OS. This error does appear to tied to the config that we are using
I modify when required !!
New Member
Message 2 of 4 (769 Views)
Re: FATAL ERROR : Unhandled e06d7363h Exception at fdaecacdh
02-07-2013 08:46 AM in reply to: steven.carlson
That is the same error I am getting but with CADWorx 2012 and AutoCAD 2013.
Any help would be apperciated!!!
steven.carlson
Message 3 of 4 (761 Views)
02-07-2013 09:25 AM in reply to: Alberto_Rodriguez
We are seeing it with
CADWorx 2010 on Autocad 2010. I'm pretty sure it has to do with our configuration setup, but I have not nailed it down just yet.
as stated before  WIN7 - 64bit OS.
Autocad behaves just fine on its own. Navisworks also behaves great.
CADWorx...not soo much.
really need a solution soon.
Product Support
Message 4 of 4 (740 Views)
02-08-2013 06:44 AM in reply to: steven.carlson
Please reach out to Intergraph to discuss these errors. Since the problem only seems to happen when using the CADWorx portion, they may already have a fix they have rolled out.
Shawn Niles
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
