AutoCAD 2010/2011/2012
Member
Message 1 of 9 (240 Views)
Accepted Solution
Assigning a layer to a command
240 Views, 8 Replies
12-07-2012 07:42 AM
A company I used to work for had a custom set of dimensioning tools in the tool palettes. We had issues with people dimensioning on the wrong layers and they included an instruction(?) in these custom commands to dimension using the correct layer i.e. current layer set to 'Border', select custom linear dim command and dim is drawn in 'Dimension' layer. My question is, does anybody know what to add to the macro in the properties when creating such a command button to do this? ^C^C_dimlinear <add something here to use a specific layer?>
Valued Contributor
Message 2 of 9 (232 Views)
Re: Assigning a layer to a command
12-07-2012 07:59 AM in reply to: Oberdiah
Try this:
^C^C-layer;_s;Dimension;;_dimlinear;
Member
Message 3 of 9 (227 Views)
12-07-2012 08:05 AM in reply to: Patchy
You legend! That's perfect, thanks :-)
*Expert Elite*
Message 4 of 9 (218 Views)
12-07-2012 09:00 AM in reply to: Oberdiah
I don't think you need a macro if you are using the palette system.  In the palette icon properties, just select the layer you want to use.
Valued Contributor
Message 5 of 9 (214 Views)
12-07-2012 09:17 AM in reply to: dbroad
dbroad,
Can you post a snap shot of how it's done? I want to know the new way.
*Expert Elite*
Message 6 of 9 (207 Views)
12-07-2012 11:56 AM in reply to: Patchy
toollayer.pngRight click the tool and choose the layer.  Layer must exist in the source drawing.  Easiest way is to drag a dimension from the source drawing to the tool palette.  For menus(.cui files), the way you demonstrated was correct.
Valued Contributor
Message 7 of 9 (198 Views)
12-07-2012 01:36 PM in reply to: dbroad
Thank you dbroad.
Member
Message 8 of 9 (168 Views)
12-10-2012 12:30 AM in reply to: Patchy
Thanks everyone for the replies, appreciated!
*Expert Elite*
vladimir.michl
Message 9 of 9 (134 Views)
12-11-2012 06:53 AM in reply to: Oberdiah
You can also setup a reactor to set a specific layer for specific commands. See e.g FLay at
www.cadforum.cz/cadforum_en/qaID.asp?tip=5131
Vladimir Michl, www.cadstudio.cz
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
