AutoCAD 2010/2011/2012
Valued Contributor
Message 1 of 3 (281 Views)
Annotation scale in Block editor
281 Views, 2 Replies
09-17-2009 02:03 AM
When I open a block in the Block editor, the annotationscale seems to switch to a random scale. When I set the correct annotationscale, save the block and reopen it, again the random scale is active.
Is there a way to permanently set the annotationscale for a block?
Simon Weel
tcorey
Message 2 of 3 (281 Views)
Re: Annotation scale in Block editor
09-17-2009 06:35 PM in reply to: Simon_Weel
Simon, are you talking about the annotative scale attached to the text objects that are within the block or the annotative scale attached to the block itself?
Tim Corey
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Distinguished Contributor
Message 3 of 3 (281 Views)
09-18-2009 04:02 AM in reply to: Simon_Weel
Neither. Lets say the drawing is set at annotationscale 1:50. In this drawing, I open a dynamic block, so I'm switched to the block editor window. In this window, the annotationscale is set to, what seems to be, a random scale. In this case 1:1000, which makes all annotative objects fill the screen. I set the annotationscale back to 1:50 and everything is normal. Close the blockeditor, saving the changes. I reopen the same block in the blockeditor and once again, the annotationscale is set at 1:1000.
I seems logic to me for the blockeditor window to use the current drawing scalefactor, but apparantly it's not?
Simon Weel
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
