AutoCAD 2007/2008/2009
Active Member
Message 1 of 4 (1,109 Views)
Accepted Solution
How to delete one(or more) of a rectangle's lines
1109 Views, 3 Replies
12-08-2012 03:04 AM
How can I delete one of the rectangle's lines? When I try selecting only one line I can't do it unless I select the entire rectangle. Help please.
For example in this photo I would like to delete line AB:
[IMG]http://i49.tinypic.com/11a9uzm.jpg[/IMG]
*Expert Elite*
Alfred.NESWADBA
Message 2 of 4 (1,105 Views)
Re: How to delete one(or more) of a rectangle's lines
12-08-2012 03:18 AM in reply to: Cantafford
if your rectangle is of type POLYLINE then it's one object. To separate the polyline into it's segments you may use command _EXPLODE, then each of the segments will a be separate line and may be deleted piece by piece.
(just to make sure: to move that object, when it's exploded, makes it necessary to select each of the pieces :smileywink: then )
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Active Member
Message 3 of 4 (1,092 Views)
12-08-2012 08:57 AM in reply to: Alfred.NESWADBA
Great thanks man!
Valued Mentor
Message 4 of 4 (1,074 Views)
12-11-2012 06:50 AM in reply to: Cantafford
Since the Rectangle is a polyline, it is an Object. As an Object, it can trim itself. Here's how.
-Start the Trim command,
-Select the Rectangle,
-Hit "Enter" to end the selecting.
-Now, select any of the Rectangle's lines and they will disappear.
The remaining pieces are still Polylines.
Try it; you'll like it. -KLYPH
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
