AutoCAD 2007/2008/2009
New Member
Message 1 of 4 (304 Views)
Creating a Tooling path for CNC
304 Views, 3 Replies
03-26-2013 12:13 PM
Is there a quick way to edit my lines to be 3/8" wide so that I can see what my images will look like after i am finished tooling them on my CNC table?
I need to make sure my images stay sharp and the lines dont overlap or intersect oce they are 3/8" thickness
Any ideas?
Is it possible to import my vectors into adobe illistrator and change the line thickness to 3/8", edit the vectors then import them back into cad as vectors?
Active Member
Message 2 of 4 (290 Views)
Re: Creating a Tooling path for CNC
03-26-2013 03:29 PM in reply to: Jeremy_greiner
Have you tried importing the CAD file to mastercam? Mastercam should be able to give you a rendered preview. I am not sure of a way to do this in AutoCad.
New Member
Message 3 of 4 (274 Views)
03-27-2013 07:07 AM in reply to: PSDstaff
Thanks pdfstaff,
this is not the route I took.
Is master cam a free software?
I was able to import / export dxf and dwg files in adobe illustrator and edit them so i could see exactly what the cuts would look like it worked perfectly! If anyone is inrested these are the steps
I import the drawing into illustrator and change the line weight according to what bit will be used.
This allows you to then see what the cuts will look like on the machine.
Inside illustrator I then edit the lines so that the tooling looks how I want it to.
I change the line weights back to the size they were in autocad to prevent them from looking (not necessary) but once the line size has been changed you cannot easily change it in autocad. So if you want to see how the drawing looks in auto cad with the bit size you have chosen you can skip this step…
I export the drawing to dwg or dxf and then open it into autocad.
You will see that the illustrator program has changed some of the arcs and lines into splines. Toolpath will not read splines so you must change them back into lines and arcs or polylines.
So I used a app that you can with one click change all your splines into polylines. It is called spline2line.lsp.
so I then go to Tools -> Load Application -> (browse for spline2pline.lsp) cad will say “loaded successfully”
in the command line I type “spline2pline” it prompts you to select object, select all your splines…. And boom you are ready to import to toolpath with the artwork you have drawn in adobe illustrator looking precisely the way you want it to be cut on the machine
Illustrator is easy to use to modify your lines and saves straight to dxf which is golden!
*Expert Elite*
Message 4 of 4 (261 Views)
03-31-2013 07:46 AM in reply to: Jeremy_greiner
Set lineweight in AutoCAD.
Plot Preview.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
