AutoCAD 2004/2005/2006
Active Member
Message 1 of 9 (288 Views)
Batch E-Transmit
288 Views, 8 Replies
06-23-2006 02:29 AM
Does anyone now of any tool set or any way to batch e-transmit, i.e. select s group of drawings in a folder and let AutoCAD create e-transmits of the files.
*Dean Saadallah
Message 2 of 9 (288 Views)
Re: Batch E-Transmit
06-23-2006 05:45 AM in reply to: warobertson
eTransmit command not do that for you?
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
Active Member
Message 3 of 9 (288 Views)
06-23-2006 06:07 AM in reply to: warobertson
I can't find this in the e-transmit command, what we want is a system that lets you select a group of drawings and then goes off and created a set of individual zip e-transmits.
Distinguished Contributor
Message 4 of 9 (288 Views)
06-23-2006 06:29 AM in reply to: warobertson
You can do it from Sheet Set Manager.
Kev
*Dean Saadallah
Message 5 of 9 (288 Views)
06-23-2006 07:38 AM in reply to: warobertson
Oh, I see, kind of like per-group or per-project?
Dean Saadallah
Active Member
Message 6 of 9 (288 Views)
06-23-2006 07:44 AM in reply to: warobertson
Yes like per project or folder of drawings that would then go of and grab all the other files required for that group and create a set of e-transmit zip files. Any help please.
*Dean Saadallah
Message 7 of 9 (288 Views)
06-23-2006 08:06 AM in reply to: warobertson
SAM90 gave one answer, using SSM. Simply go through each
pre-set Sheet set, one for each project, right-click and
select eTransmit at the top level of each 'project' sheet
set.
Otherwise I don't know of a way to have AutoCAD find your
projects on it's own and do it all for you.
Dean Saadallah
Message 8 of 9 (288 Views)
06-23-2006 08:21 AM in reply to: warobertson
Are you aware you can add files with e-transmit?
Message 9 of 9 (288 Views)
06-23-2006 08:25 AM in reply to: warobertson
...you can also add your plot files [.dwfs, .plts, etc]
With SSM you can make one .dwf file containing all drawings for one project.
HTH
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
