AutoCAD 2000/2000i/2002 Archive (Read Only)
How can I set the support paths without going to every station
10 REPLIES 10
Message 1 of 11
353 Views, 10 Replies
I am trying to setup AutoCAD 2000i on our system of 25 cadd users. I would
like to be able to add some entries to the support paths for the users home
directory and the pc3 files that will be stored on the network.
How can I do this without going to every station and running the chance
that the users will later change the settings?
What I can see doing do far from the AutoCAD help would be to manually add
entries to each support path with a DOS environment variable. As an example
I could set a environment variable called JobDir and then in the Project
Path add the entry %JobDir% to use this path when AutoCAD starts. This
would mean going to every station though to add these environment
variables.
Are there already equivalent AutoCAD environment variables that can be set
before acad starts? Do the old acad=, acaddrv=, acadcfg= still work like
acad12?
Is there a better way for creating a consistent network setup?
David Patnaude, MCSE, MCP+I
dpatnaude@tamsconsultants.com
10 REPLIES 10
Message 2 of 11
What type of OS are you running on your server?
"David Patnaude" wrote in message
news:8F84560A8dmpziplink@167.216.240.240...
home
example
> variables.
> acad12?
Message 3 of 11
You should definitely have AutoCAD always
installed in the same folder, and then using
Profiles will massively speed up the task.
But adding specifically named folders for each
user's personal folder would require some trickiness.
-- Jeremiah
Lifted Axis
www.liftedaxis.com
Great AutoCAD Tools starting at $10
Message 4 of 11
David,
here's a way to do it, can be placed in a lisp that is loaded at start...
(setenv "ACAD" (strcat (getenv "ACAD") ";" "r:\herecomesthepath"))
if you want more info post at customization
Best regards: Jimmy B
CAD coordinator at Emtunga International AB
http://hem.fyristorg.com/cadman/
www.emtunga.com
"David Patnaude" wrote in message news:8F84560A8dmpziplink@167.216.240.240...
> variables.
> acad12?
Message 5 of 11
yarbrough@envirogenm.com (Tobi Yarbrough) wrote in
>> would like to be able to add some entries to the support paths for the
>> users
>home
>> chance that the users will later change the settings?
>> add entries to each support path with a DOS environment variable. As
>> an
>example
>> Project Path add the entry %JobDir% to use this path when AutoCAD
>> starts. This would mean going to every station though to add these
>> environment variables.
>> set before acad starts? Do the old acad=, acaddrv=, acadcfg= still
>> work like acad12?
NetWare 5.1 server. Clients are Win95 and Win NT Workstation.
Message 6 of 11
froggy@liftedaxis.com (Jeremiah Farmer) wrote in
>-- Jeremiah
>Lifted Axis
>www.liftedaxis.com
Once I rollot out the clients, they will all be installed the same way from
the network install so that should work out ok. We have a network
license running on NetWare 5.1. With the profiles, is there a way to
automatically add a profile. I know the /p switch will load a specific
profile, but how do you get the profile to each machine?
Message 7 of 11
cadman@yesbox.net (Jimmy B) wrote in :
>David,
Thanks, I like that one. It is easy to copy acad.lsp to every machine and
then it will be all set. I assume this works for any of the ACAD
environment variables since I also want the plotter config files to be in a
network folder to be accessed by all clients.
Message 8 of 11
I haven't found an automatic way to handle profiles.
But tantamount in any draftperson's training is
where the Fonts folder is on the network, where
the Incoming and Outgoing email and FTP folders
are, and where the Profile folder is. Whenever any
changes are made to their toolbars, they should
export their Profile to the folder, and whenver anything
is screwy with their AutoCAD, they should import
their saved Portfolio before waking up the IT guy.
-- Jeremiah
Lifted Axis
www.liftedaxis.com
Message 9 of 11
>-- Jeremiah
>Lifted Axis
>www.liftedaxis.com
I wish it were that easy here. I can type out instructions for this stuff,
distribute it to everyone, and they will still call.
Message 10 of 11
It also works with
\Plotters is "PrinterConfigDir"
\drv is "PrinterDescDir"
\Plot Styles is "PrinterStyleSheetDir"
\Templates is "TemplatePath"
\Data Links is "DatabaseWorkSpacePath"
www.emtunga.com
Message 11 of 11
Another solution might be to create a standalone
executable that they can run to set their registry
settings. Or, even a REG file sitting on each machine's
desktop that they can double-click, resetting all
the Acad profile stuff.
-- Jeremiah
Lifted Axis
www.liftedaxis.com
