AutoCAD 2000/2000i/2002 Archive (Read Only)
118 Views, 4 Replies
2002 and 2000
Any problems having both installed on the same computer?
4 REPLIES 4
Hi, Kirk,
beside the other opinion here, there IS a chance to have bot versiosn
running ...
Acad2000 & Acad2002 will share the same Registry key ONLY if both Acads have
the same language AND the same vertical flavour ....
If you use Acad2000 (Vanilla) & Acad2002 MAP/MDT/LDT (or vice versa), both
Acads
will use DIFFERENT Registry keys.
The other problem are the files from "...\Shared iles\\Autodesk Shared\" :
- after installing Acad 2000's files, simply move all the shared folder's
files into the Acad 2000's root
- then, after installing Acad 2002's files, simply move all the shared
folder's files into the Acad 2002's root
for both Acads, remove the Shared Folder from the support paths setting
("Options/Files/Support files"), if there is an entry ....
There is a more detailled description in this newsgroup (or even in
Acad2002General newsgroup)
good luck
Torsten Moses
Hi, Kirk,
I have forgotten :
On my machine, I have 5 Acad 14/2000/2000i/2002 running -:)
and also the same-version LTs ...
Torsten Moses
Can't be done, unless you have a dual-booting computer with two operating
systems. 2000 and 2002 have the same file format and share a number of
registry settings, so it's simply not possible to have both running side by
side.
The exception to this is if either version is part of a Desktop application.
E.g., you can run Architectural Desktop 3 (based on AutoCAD 2000) and
AutoCAD 2002 in the same setup.
Dave Byrnes/Vancouver BC
Autodesk Forum Moderator Program
Please DO NOT send technical requests to me via private e-mail.
Use CTRL+G to reply and KEEP IT IN THE NEWGROUP!
Kirk Otteson wrote in message
news:f0addb5.-1@WebX.maYIadrTaRb...
Thank You, I Have 14 and 2000 running with no problems. That's why I
wondered. I can't think of any advantages to having both anyway. Thanks
again.
"Dave Byrnes" wrote in message
news:1A4F7E183A0504BC8B8462C81A7856EB@in.WebX.maYIadrTaRb...
by
> side.
application.
