Hi, Kirk,
beside the other opinion here, there IS a chance to have bot versiosn
running ...
Acad2000 & Acad2002 will share the same Registry key ONLY if both Acads have
the same language AND the same vertical flavour ....
If you use Acad2000 (Vanilla) & Acad2002 MAP/MDT/LDT (or vice versa), both
Acads
will use DIFFERENT Registry keys.
The other problem are the files from "...\Shared iles\\Autodesk Shared\" :
- after installing Acad 2000's files, simply move all the shared folder's
files into the Acad 2000's root
- then, after installing Acad 2002's files, simply move all the shared
folder's files into the Acad 2002's root
for both Acads, remove the Shared Folder from the support paths setting
("Options/Files/Support files"), if there is an entry ....
There is a more detailled description in this newsgroup (or even in
Acad2002General newsgroup)
good luck
Torsten Moses
