i am trying to learn rigging for character models however when i try and paint weights after adding a skin modifer and adding the bones i am unable to reduce the painted weights, ive tryed editting the settings but that didnt help, i am still able to add weight to polygons and change the ammount at which they add but i cant remove existing painted weights or remove those i add. which makes it nearly impossible to learn because i obviously need to "rub it out" for want of a better phrase. after watching a tutorial the person said to hold alt to remove the painted weight but that didnt work and ive tryed every combination of shortcuts i could think of. eveerything else works fine, its only this. ive re-downloaded, repaired, should be up to date. it just doesnt want to work. the same thing happened in 2012 which is reallt confusing as i am now using a different version aswell as a different computer. any help is greatly appreciated, thanks.
