Why the final render is not clear ????
and the Vray message says there are warning ( material sundero_metal has unlocked highlight and reflection glossiness :this is no longer supported and will be ignored )
what is the solution ???
Francisco_Penaloza
You are using a newer version of V Ray than the version of that material.  If you are importing models from some else or older models, V Ray will suggest correcting all those old shaders to the new system.
You image look noisy or pixelated because it doesn't have enough samples or time to render.
I am guessing you are using Progressive rendering and by default, it will stop at 1 minute.
Please refer to the Help Doc of VRay, everything is very well explained over there and follow some of the quick tutorials and you'll be up and running with VRay very quickly.
Best luck.
