3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Why doesn't "shaded materials with maps" work? (picture)
2 REPLIES 2
oyvind3BPMJ
249 Views, 2 Replies
The reverse of this works, the "Materials - shaded materials without maps" effectively removes textures.
But I have a Multi/Sub object material that refuses to show textures again when using shaded materials with maps
To get the textures back, I need to manually click the "Show shaded material in viewport" and then from the dropdown (pic) select one of the two
It would be extremely useful to hide the characters texture during skinning!
2 REPLIES 2
10DSpace
in reply to: oyvind3BPMJ
@oyvind3BPMJ
Why not just switch to Shaded: object color in Display tab for skinning and back to Material color when done?  That's what I do when I want to hide textures for some task.
oyvind3BPMJ
in reply to: 10DSpace
Thanks that did the trick!
I ended up making a hotkey for it using this script, if anyone else wanted the same thing, so just add this script to the user macros folder, run it (or restart), and find it under the name TextureToggler in hotkeys
macroScript TextureToggler
	category:"DragAndDrop"
	toolTip:"TextureToggler"
	if displayColor.shaded == #material then displayColor.shaded = #object else displayColor.shaded = #material
Technology Administrators
