White dots while rendering using v ray.
c.jpgI  already tried switching on sub pixel mapping   but I had no luck in resolving the issue.
jackietsteh
Try change your vraylight material multiplier to 1.0, and check on the compensate Camera Exposure.
Best regards,
Jackie Teh
Portfolio: http://www.coroflot.com/jackieteh
Youtube Channel:https://www.youtube.com/user/jackieteh
Francisco_Penaloza
Yes, this seems to happen when your lights or self-illuminated objects are too bright for the sampler to resolve.
One way could be giving more samples, another way is using subpixel mapping, but you'll need to use the campling options for better results.
You could change your color mapping to Reinhard and reduce the burning to something like 0.4. this will make the whole image look a little washed out, but you can bring contrast back in the VRay frame buffer or in photoshop.
miledrizk
In addition to the good advices mentioned above, i like to add one thing,
In Vray tab, Image Sampler(AntiAliasing) rollout, Image Filter group, choose
One of Vray's filters, like VrayLanczosFilter
[email protected]
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
You found the solution.Setting Vray light material to 1 and check on the compensate Camera Exposure solved the problem.
